Hi I’m Nednapa. I’m doing my senior project and I need your help. I set up my device and it told me to do it through the website. When I try to set up on the website. It show in the as the first picture. And I stuck there. Then I try to register my sim card and it shown as the second picture. So…
Will I get the hex string if I done registration?
If it need registration, is there a way to register without using credit card number?
If all of this is my misunderstanding, can you please suggest me how to do?
ps. here is my email address REDACTED [MOD: Please don’t post your email address]
Could you explain what the problem with the credit card number is?
I couldn’t get that out of any of your previous posts, you just said, it’s stuck there.
Have you not got a credit card?
For activating your SIM card, you won’t need the device ID, so your second screenshot has nothing to do with the SIM card.
The device ID is required to claim the device (not the SIM card) but for that your device has to be breathing cyan first, which it won’t unless you get your SIM card got activated.
You can either get a (prepaid) creditcard or try a different (normal) SIM card. You’ll have to enter their settings manually, but it should work just as well.
What kind Electron do you have? Is it compatible with your SIM`s band?
Have you flashed a code setting your SIM’s APN on your Electron?
Have you gone through https://setup.particle.io again and entered your SIM’s ICCID there?
If you did, you should have got this page, where you can download a binary to flash onto your Electron setting the corrected APN
I have already done the step that you’ve told. Now I’ve already downloaded firmware.bin. But I can’t flash the firmware. I typed “particle flash 46005f00025135333735307 firmware.bin” but it couldn’t find firmware. So, I type “particle flash 46005f00025135333735307 C:\Users\Downloads\firmware.bin” but still not work. I also remove my simcard before I did this. I try “https://api.particle.io/v1/devices/46005f00025135333735307/” and didn’t work. Do you have any ideas what I should do?
Now I can flash the firmware.bin and already complied the code(.ino) but I cannot flash them into device whether in listening mode or DFU mode. It said that I’ve to flash via OTA, but when I confirm the number like 0.005mb It still not work.Can you please help me?
That means that the version your binary is targeting (currently default 0.5.2) does not match the system version of your device.
You either need to update the device or target the correct system with your binary.
