Electron 3rd-party SIM tips
The [Particle Electron] (https://www.particle.io/products/hardware/electron-cellular-dev-kit) comes with a SIM card that allows easy and [often inexpensive] (https://www.particle.io/pricing#cellular-data) 2G or 3G cellular access.
Sometimes, however, you may want to use a different mobile provider. You may need to transfer large amounts of data, which may be cheaper on another provider, or you may need to use the Electron in a country that’s not supported by the Particle SIM. Fortunately, the Electron can easily be used with 3rd-party SIM cards.
Several of the steps below require the Particle CLI, so if you haven’t installed it yet, you should do so now. The installer and instructions are at the [bottom of CLI page] (https://particle.io/cli).
All SIMs, including 3rd-party SIMs, must be activated. The method for activating varies by carrier; you might do this from a web site or with a phone call. If you’re using the SIM that was in your phone, it’s already activated. Being activated or not is part of the state of the SIM and doesn’t depend on what device it’s being used in.
Activation is different than claiming an Electron, which adds the Electron to your account. Claiming is discussed below.
About ICCIDs
Every SIM card has an ICCID (“integrated circuit card identifier”) that uniquely identifies the card. The number is usually 19 or 20 digits long and is usually printed on the card, though some carriers only print part of the number on the card.
Assuming your phone accepts nano-sized SIM cards (iPhone 5 and later, for example), your phone can show the ICCID. On the iPhones, it’s in Settings - General - About - ICCID.
The location varies on Android phones, and sometimes it’s called the SIM ID or SIM Number instead of ICCID. There are other numbers like the IMSI and IMEI that are different, and shorter.
You can also easily find out the ICCID using the Particle CLI. Connect the Electron by USB to your computer. Hold down the MODE button until the main status LED blinks blue, then release. Issue the command:
particle identify
About SIM PINs
The Electron does not currently support SIM cards with a PIN. If your SIM card requires a PIN, even if it’s 0000, you must remove the PIN before it will work in the Electron.
The easiest way to remove a SIM PIN is from a phone. On the iPhone, it’s in Settings - Phone - SIM PIN.
Using setup.particle.io with 3rd-party SIM
Using the standard setup at [https://setup.particle.io] is the easiest way to get started. You’ll need the ICCID of your 3rd-party SIM card.
Sign in and select the left option, Particle Setup an Electron w/SIM card.
You’ll then be taken to the page for non-Particle SIM cards.
You can follow the instructions on the page to complete setup. There are some additional hints below, as well.
Finding your APN
The APN (“Access Point Name”) specifies how the Electron should connect to the Internet. The setting varies by carrier, and sometimes by country. If you’re searching Google for your APN, be aware that some carriers may list separate WAP APN or MMS APNs; you want to use the Generic or Internet APN.
There is no set structure to an APN. Here some examples: broadband, internet, three.co.uk.
If you have set your APN correctly the Electron should proceed through the normal states: breathing white, blinking green, blinking cyan, fast blinking cyan, and finally to breathing cyan, even before you’ve claimed the Electron. In fact, the Electron must be in breathing cyan to complete the claiming process.
Some carriers may also require a username and password. Note those, if they are required, as well.
Making Tinker with APN setting
One of the features of setup.particle.io is the ability to download a version of Tinker (the default user firmware on your Electron) that sets the APN for your SIM card.
You can also just build your own. Copy and paste this into a file, such as tinker.ino.
#include "Particle.h"
// Set your 3rd-party SIM APN here
// https://docs.particle.io/reference/firmware/electron/#setcredentials-
STARTUP(cellular_credentials_set("epc.tmobile.com", "", "", NULL));
/* Function prototypes -------------------------------------------------------*/
int tinkerDigitalRead(String pin);
int tinkerDigitalWrite(String command);
int tinkerAnalogRead(String pin);
int tinkerAnalogWrite(String command);
SYSTEM_MODE(AUTOMATIC);
/* This function is called once at start up ----------------------------------*/
	// Set the keep-alive value for 3rd party SIM card here
	// https://docs.particle.io/reference/firmware/electron/#particle-keepalive-
	Particle.keepAlive(120);
	//Setup the Tinker application here
	//Register all the Tinker functions
	Particle.function("digitalread", tinkerDigitalRead);
	Particle.function("digitalwrite", tinkerDigitalWrite);
	Particle.function("analogread", tinkerAnalogRead);
	Particle.function("analogwrite", tinkerAnalogWrite);
/* This function loops forever --------------------------------------------*/
	//This will run in a loop
 * Function Name  : tinkerDigitalRead
 * Description    : Reads the digital value of a given pin
 * Input          : Pin
 * Output         : None.
 * Return         : Value of the pin (0 or 1) in INT type
                    Returns a negative number on failure
	//convert ascii to integer
	int pinNumber = pin.charAt(1) - '0';
	//Sanity check to see if the pin numbers are within limits
	if (pinNumber < 0 || pinNumber > 7) return -1;
	if(pin.startsWith("D"))
		pinMode(pinNumber, INPUT_PULLDOWN);
		return digitalRead(pinNumber);
	else if (pin.startsWith("A"))
		pinMode(pinNumber+10, INPUT_PULLDOWN);
		return digitalRead(pinNumber+10);
#if Wiring_Cellular
	else if (pin.startsWith("B"))
		if (pinNumber > 5) return -3;
		pinMode(pinNumber+24, INPUT_PULLDOWN);
		return digitalRead(pinNumber+24);
	else if (pin.startsWith("C"))
		if (pinNumber > 5) return -4;
		pinMode(pinNumber+30, INPUT_PULLDOWN);
		return digitalRead(pinNumber+30);
#endif
	return -2;
 * Function Name  : tinkerDigitalWrite
 * Description    : Sets the specified pin HIGH or LOW
 * Input          : Pin and value
 * Output         : None.
 * Return         : 1 on success and a negative number on failure
	bool value = 0;
	int pinNumber = command.charAt(1) - '0';
	if(command.substring(3,7) == "HIGH") value = 1;
	else if(command.substring(3,6) == "LOW") value = 0;
	else return -2;
	if(command.startsWith("D"))
		pinMode(pinNumber, OUTPUT);
		digitalWrite(pinNumber, value);
		return 1;
	else if(command.startsWith("A"))
		pinMode(pinNumber+10, OUTPUT);
		digitalWrite(pinNumber+10, value);
		return 1;
#if Wiring_Cellular
	else if(command.startsWith("B"))
		pinMode(pinNumber+24, OUTPUT);
		digitalWrite(pinNumber+24, value);
		return 1;
	else if(command.startsWith("C"))
		if (pinNumber > 5) return -5;
		pinMode(pinNumber+30, OUTPUT);
		digitalWrite(pinNumber+30, value);
		return 1;
#endif
else return -3;
 * Function Name  : tinkerAnalogRead
 * Description    : Reads the analog value of a pin
 * Input          : Pin
 * Output         : None.
 * Return         : Returns the analog value in INT type (0 to 4095)
		return -3;
		return analogRead(pinNumber+10);
#if Wiring_Cellular
		if (pinNumber < 2 || pinNumber > 5) return -3;
		return analogRead(pinNumber+24);
#endif
	return -2;
 * Function Name  : tinkerAnalogWrite
 * Description    : Writes an analog value (PWM) to the specified pin
 * Input          : Pin and Value (0 to 255)
 * Output         : None.
	String value = command.substring(3);
	if(command.substring(0,2) == "TX")
		pinMode(TX, OUTPUT);
		analogWrite(TX, value.toInt());
		return 1;
	else if(command.substring(0,2) == "RX")
		pinMode(RX, OUTPUT);
		analogWrite(RX, value.toInt());
		return 1;
		analogWrite(pinNumber, value.toInt());
		return 1;
		analogWrite(pinNumber+10, value.toInt());
		return 1;
	else if(command.substring(0,2) == "TX")
		return 1;
		return 1;
#if Wiring_Cellular
	else if (command.startsWith("B"))
		if (pinNumber > 3) return -3;
		analogWrite(pinNumber+24, value.toInt());
		return 1;
	else if (command.startsWith("C"))
		if (pinNumber < 4 || pinNumber > 5) return -4;
		analogWrite(pinNumber+30, value.toInt());
		return 1;
#endif
else return -2;
Put the Electron in DFU mode ([blinking yellow] (https://docs.particle.io/guide/getting-started/modes/electron/#dfu-mode-device-firmware-upgrade-)) by holding down the RESET and MODE buttons, releasing RESET and continuing to hold down MODE while the main status LED blinks magenta until it blinks yellow. Then release MODE.
particle compile electron --target 0.4.8 tinker.ino --saveTo firmware.bin
particle flash --usb firmware.bin
You can flash an Electron with code even before you’re claimed it or gotten connected to the Internet. In fact, you’ll have to when you’re using a 3rd-party SIM.
About APN setting (lack of) persistence
The APN setting is not stored in configuration flash on the Electron. Thus you should include it in every program that you run on the Electron that uses a 3rd party SIM. This is different than the Photon, where configuration parameters like Wi-Fi settings are stored in configuration flash.
In other words, even though you flashed a APN setting Tinker to your Electron, you still need to set the APN in your own user firmware, because the setting is not saved.
You can be fooled into believing otherwise, because the APN is actually stored in the cellular modem, and flashing new user code or using the RESET button doesn’t completely reset the modem to save time and data usage. So it looks like the setting sticks, but as soon as you completely power down the modem by unplugging the battery or using deep sleep the APN setting will go away.
Claiming an Electron manually
In addition to using the setup.particle.io method above, once your Electron is breathing cyan after successfully setting the APN.
You’ll need the device ID of your Electron. You can get it by putting the Electron in [listening mode] (https://docs.particle.io/guide/getting-started/modes/electron/#listening-mode), blinking dark blue, by holding down the MODE button until the main status LED blinks blue, then issuing the CLI command:
particle identify
The device ID is different from your SIM ICCID.
Claiming from Particle Build (Web IDE)
Click the devices icon in the lower left corner of the Particle Build [https://build.particle.io] (https://build.particle.io) window.
At the bottom of your list of devices is Add New Device button. Click that and enter the device ID.
Claiming from Particle Dev (Atom IDE)
Using Particle Dev on Windows or Mac, select Claim Device… from the Particle menu and enter the device ID.
Claiming from the CLI
With the Electron in breathing cyan mode, issue the CLI command:
particle device add YOUR_DEVICE_ID
About keep-alive
When mobile devices, including phones and the Electron, connect to the Internet they share a connection through their mobile carrier, similar to how multiple computers in your home share a connection through your home router.
When the Electron sends data to the Particle cloud, the carrier also opens up a reverse channel to allow the Particle cloud servers to send data back to the device.
(Technically speaking, the Electron sends UDP data out, and the carrier creates port forwarding to a UDP listening port on the Electron to get data back.)
These return data channels take up resources on the carrier network, so they like to clean up the unused ones to free up the resources. The Particle SIM has an unusually long timeout of 23 minutes. Most carriers use a timeout of between 30 seconds and several minutes.
When the return channel is freed, the Electron will continue to breathe cyan, because it doesn’t know that it has occurred. Also, it will still be able to send data to the cloud, so things like Particle.publish will work, and will also restart the return channel if it has been cleaned up.
The problem is that without a working return channel the following things don’t work properly:
  • Subscriptions using Particle.subscribe sending data to the Electron
  • Calling Particle functions on the Electron
  • Getting the value of Particle variables on the Electron
  • OTA code flash
If you’re using a 3rd-party SIM card you almost certainly will need to use the [Particle.keepAlive()] (https://docs.particle.io/reference/firmware/electron/#particle-keepalive-) function. It’s typically added to setup and the parameter is in seconds.
Each keep-alive ping uses 122 bytes of data, so you want to make it as long as possible for it to work with your carrier.
One way to determine the correct interval is to run the Tinker firmware on your Electron with the APN set. Reset the Electron then wait an interval before using a Particle function like:
particle call YOUR_DEVICE_NAME digitalWrite "D7=HIGH"
particle call YOUR_DEVICE_NAME digitalWrite "D7=LOW"
Find the shortest interval where the calls still work, and that’s what you should set as your keep-alive. It’s usually between 30 seconds and several minutes.
Also note that the keep-alive settings is only in Electron system firmware 0.5.0 and later, so if you have the original factory default firmware 0.4.8 you’ll need to upgrade the system firmware.
Switching between Particle and 3rd-party SIM cards
The only thing you need to do when switching between Particle and 3rd-party SIM cards is update the firmware to set or not set the APN and keep-alive, completely power down the Electron, swap the SIM card, and power it back up.
You don’t need to do anything with the cloud settings or claiming when swapping between SIM cards.
Electron models and cellular bands
The 3G Electrons come in two varieties, the Americas/Australia (U260) and Europe/Asia/Africa (U270).
The lines are not that clearly drawn, however, and may vary by carrier in a given country. For example:
In Australia, we recommend the U260 because the carrier used by the Particle SIM, Telstra, primarily uses 850 MHz. However, if you are using a 3rd-party SIM from Optus, you’ll need the U270 because Optus uses 900/2100 MHz.
In Uruguay, the carrier used by the Particle SIM, Movistar, uses 1900 MHz so the U260 Americas model is the correct one. If you’re using an Ancel SIM, however, that uses 2100 MHz you you’ll nee the U270 model, instead.
The U260 model supports 850/1900 MHz for both 3G (UMTS/HSPA) and 2G (GPRS/EDGE).
The U270 model supports 900/2100 MHz for 3G (UMTS/HSPA) and 900/1800 MHz for 2G (GPRS/EDGE).
More troubleshooting tips
Blinking Blue
If, when you power on the Electron, it’s blinking dark blue ([listening mode blue] (https://docs.particle.io/guide/getting-started/modes/electron/#listening-mode)), the most common cause is that the SIM is loose. Try removing it and putting it back in again.
Or you can try to either gently lift the little metal prongs that contact the SIM with a pin (with power off and SIM card removed) or push down on the little metal holder to get a better contact.
Stuck on blinking green
If the Electron never progresses past [blinking green] (https://docs.particle.io/guide/getting-started/modes/electron/#looking-for-internet), it probably can’t contact a cellular tower. There are several possible reasons for this:
  • No coverage on the required band. For example, you have a 2G Electron but no 2G coverage. 2G coverage may be different than 3G, 4G or LTE coverage.
  • No coverage from the selected carrier/SIM.
  • Incompatible Electron (U260 when you need a U270 for example)
  • Antenna problem
Also note that the 2G Electron is not supported in Japan. It will be discontinued in Australia at the end of 2016, and has limited coverage in some parts of the United States. Other countries may phase out 2G as well, this is often referred to as “2G Sunset.”
Blinking magenta
[Blinking magenta] (https://docs.particle.io/guide/getting-started/modes/electron/#safe-mode) is safe mode, and is an entirely different problem than connectivity. You can find more about safe mode in [this post] (Safe mode explained).
Electron troubleshooting app
The Electron troubleshooting app allows you to test individual features of connectivity. A report from this tool is helpful if you have a problem that you need to report to technical support.
[https://docs.google.com/document/d/1U_Wzy2SPRC3hZnKtw8d6QN2Tm8Q7QwtEbSUAeTkO3bk] (https://docs.google.com/document/d/1U_Wzy2SPRC3hZnKtw8d6QN2Tm8Q7QwtEbSUAeTkO3bk/edit)
Electron tester
This program can print some useful information about your cellular connection that may be helpful for debugging:
  • Model information
  • ICCID, IMEI, IMSI numbers
  • Cellular operator (“AT&T” for example)
  • Signal strength (RSSI) and quality
  • Cellular band (“UMTS 850” for example)
[https://github.com/rickkas7/electron_cellular] (https://github.com/rickkas7/electron_cellular)
This is an Excellent write-up! Thanks for this :smiley:
Thanks Rick!
@rickkas7
Thank you Rick for such a nice article. :+1:
Are you planning to make this article as part of Electron Documentation?
Regards
Mahesh
Thank you for a great tutorial. Helped me a lot being new to the platform.
Using both AUTOMATIC mode and SEMI AUTOMATIC mode (to save reconnection data), I have seen that publish also seems to fail quite a bit without sufficiently short keep alive period with 3rd party SIM.
Hi @rickkas7. Ta for the library… I will be using it to test with a 3rd party sim and gain some insight into the quirks of the Cellular calls.
I don’t know if anyone has offered this potential correction, and I’m yet to sort our a github logon to do it via that channel, so you may wish to review the switch statement in function CellularHelperCommonResponse per below:
case TYPE_BUSY:
typeStr = "TYPE_NODIALTONE";
break;
I presume this is an error, but maybe not.
[Edit] Although, I suspect no-one would ever be affected by it, as the M2M sim has no calling capability, of course, so TYPE_BUSY is a non-event (excuse the pun).
Cheers,
Andrew
Yes, TYPE_BUSY is a copy paste error. I’ve corrected it in Github and the next time I update the library in the community libraries it will have the change.
Is there a minimum upload/download speed that the 3rd party SIM must support? For example, I have a GSM mobile SIM with 64 KBps upload speed. Would that work with the Electron (U260 model- 850/1900 MHz) ? Thank you
Hi @rickkas7, thanks for the write-up!
So I’m having the problem of breathing deep blue, then goes into listening mode. Funny thing is that my electron was working properly and all of a sudden it stopped working, I assumed it was the pins holding the sim card, I tried gently pulling them out, put my sim card again and it’s not working.
Any help please?!
If it’s really breathing blue the most likely reason is the code putting the device into that state.
https://docs.particle.io/guide/getting-started/connect
e.g via Cellular.disconnect() or in a non-AUTOMATIC mode not calling Cellular.connect() or Particle.connecct().
Two quick questions. In the US are the MOVISTAR sims for the Electron 3G sitting on the AT&T network? I think yes. Also, from a “fleet of products” management perspective what are we missing if we choose to go with 3rd party sims?
The Electron 3G with the Particle SIM will use either AT&T or T-Mobile.
The main difference is that 3rd-party SIMs are only supported for developer accounts (up to 100 devices) and small product roll-outs (under 100 devices).
If you are rolling out a product at scale, you will have to pay the device cloud fee (US$2.99/month) even if you use a 3rd-party SIM card.
@rickkas7 I am using manual system mode, system thread, and a 3rd party sim, when I call Cellular.connect on first boot, it never connects (flashes green continuously) even though I have STARTUP(cellular_credentials_set(blahblahblah)) AND cellular_credentials_set in the application code, but after one reboot (pressing reboot button or calling System.reset()) it will connect very quickly (if power is removed completely, it will fail on first boot again). Can you think of any reason why this could be? Do I need to get funky with calling Cellular.off/on/connect and cellular_credentials_set in some specific order? It’s been bothering me for weeks and I am completely stumped.
@ColinVT - the short answer is yes, probably.
The people here are helpful, but you probably need to show what you've done, already, rather than expect them to shoot in the dark.
An extract from your code, perhaps, showing what you've tried?
I have a system that runs in the same mode, and 'gets funky' with iterating through the Cellular and Particle calls to establish 'cloud' connection (breathing cyan).
On a cold boot it can take some minutes (up to 5) for the modem to connect to the cellular provider. you have to allow for that.
When it is reset, only the microcontroller is reset so the modem remains connected to the provider and therefore connects quickly.
What I was trying to explain was that for instance:
1.) Cold boot device, wait until it is flashing green (attempting to connect to cellular)
2.) Let it blink green for about 5 seconds
3.) Press the reset button
4.) The device will again boot and flash green but now for no more than 10-20 seconds maximum before rapid cyan -> breathing cyan-> normal operation.
However on a cold boot, if you simply let the device run and don’t press reset (or any other type of soft reset), it will flash green for minutes on end before timing out and restarting the connection, after which it will connect quickly as described above. There is clearly a hangup somewhere here because in the above instance where the device is soft rebooted, the modem has only been on for no more than 30-45 seconds, however in the instance where it is cold booted with no soft reset, it will blink green for minutes with no success. I have worked around this for the moment by having an event handler upon the device beginning a connection attempt which will time out after 20 seconds (if the connection successful handler is not triggered) and reboot the device, which has worked just fine (since these devices are rarely cold booted).
Also here is the code I’m currently using to connect, however I didnt paste it originally as I’ve tried many different options and was mainly looking for a known-working example from someone else so that I could rule out the order in which I’m calling these functions as the culprit.
Here is my getConnected function:
int getConnected()
  Cellular.on();
  Particle.disconnect();
  DBG_SERIAL_CONSOLE.printlnf("Allowing cell modem to initialize...");
  delay(modemTurnOnDelayTime());
  while (!setupCellCredentials(&cellCredentials)) {
     delay(10);
  delay(100);
  DBG_SERIAL_CONSOLE.println("[Cell]: setting credentials");
  DBG_SERIAL_CONSOLE.println("APN: " + String(cellCredentials.APN_name));
  DBG_SERIAL_CONSOLE.println("user name: " + String(cellCredentials.userName));
  DBG_SERIAL_CONSOLE.println("password: " + String(cellCredentials.passWord));
  DBG_SERIAL_CONSOLE.println("keep alive: " + String(cellCredentials.keepAlive));
  cellular_credentials_set(cellCredentials.APN_name, cellCredentials.userName, cellCredentials.passWord, NULL);
  DBG_SERIAL_CONSOLE.println("Calling Cellular.connect");
  Cellular.connect();
  while (!Cellular.ready()) {
     delay(10);
  delay(100);
  // Connect to cloud. This is necessary because manual mode is turned on.
  DBG_SERIAL_CONSOLE.println("Calling Particle.connect");
  Particle.connect();
  while (!Particle.connected()) {
     delay(10);
  Particle.keepAlive(cellCredentials.keepAlive);
  DBG_SERIAL_CONSOLE.println("[Particle] connected");
From watching serial, I can confirm that it does successfully detect the correct sim & settings from the card, even on cold boot.
We’d need to see how things happen chronologically in your code.
Your snippet does not show what SYSTEM_MODE() you are using nor does it show at which point in time you call cellualr_credentials_set()
Sorry, I thought I had already mentioned this, I am using this for setting up of the cell credentials:
However this issue is still present if I completely cut out that portion, and just set the exact cell credentials in STARTUP() as described in the electron's docs. The workaround I have been using is working fine and this is not a priority whatsoever at this point as I've adapted our firmware for use on the Boron and Argon which we will be moving toward in the near future (and I do not have this issue using the same order of functions on the boron). Anyways, the reason I say this is that I don't want people spending time and brainpower helping me with this since it's more of just a minor nuisance to me when other people probably have far more pressing issues (and as it doesn't seem to be impacting anyone else, its likely some wonky thing I'm causing inadvertently).
I have just added these lines to my code in order to use 3rd party sim card but not successful, is there any thing i can do,
STARTUP(cellular_credentials_set("goto.virginmobile.uk", "", "", NULL));
its still flashing green then to listening mode (dark blue) and cannot connect to cloud,
this electron i used was using particle sim card, so its already sat up.
your advice please
thanks
Was that device fully setup before?
If not, try particle usb setup-done
