I get the following error when compiling in the command line.
C: ... \Blinky>particle compile p blinker.ino
Compiling code for photon
Including:
blinker.ino
pushing file: blinker.ino
compile got error: { [Error: read ECONNRESET] code: 'ECONNRESET', errno: 'ECONN
RESET', syscall: 'read' }
Compile failed. Exiting.
I can compile just fine is Particle Dev. Compiling used to work for me in the command line but hasn’t since I got DFU-Util installed and working.
Whenever I see the ECONNRESET elsewhere on this forum there’s another error associated with it, but I don’t see that in this case.
ScruffR
November 11, 2015, 12:50pm
2
Could you try
npm update -g particle-cli
and then try to compile a minimum sketch like this
void setup() { }
void loop() { }
I get the same error.
C: .. \min>particle compile p min.ino
Including:
min.ino
pushing file: min.ino
I also didn’t get any feedback after running update. It waited for a few seconds and then continued
ScruffR
November 11, 2015, 1:06pm
4
Do you get any other response of CLI e.g. for particle list?
I do get response from particle list. It searches for devices and then returns:
C:>particle list
@ Retrieving devices...listDevices got error: { [Error: read ECONNRESET] code:
'ECONNRESET', errno: 'ECONNRESET', syscall: 'read' }
Potentially unhandled rejection [2] Error: read ECONNRESET
at exports._errnoException (util.js:746:11)
at TCP.onread (net.js:559:26)
Potentially unhandled rejection [3] Error: read ECONNRESET
I am able to flash over USB using “particle flash --usb”
ScruffR
November 11, 2015, 1:18pm
6
Hmm, that looks as if your node.js (or less likely particle-cli) got somehow damaged.
Try npm uninstall -g particle-cli and npm install -g particle-cli first and if this does not help, you might have to reinstall node.js.
Trying that now. I am on satellite internet here, which is why I am flashing locally. Could that effect anything?
ScruffR
November 11, 2015, 1:24pm
8
It might, depending on the connection quality (interruptions) and latency (timeouts).
Wasn’t able to reinstall particle-cli. Lot’s of errors, but the first was this
MSBUILD : error MSB3428: Could not load the Visual C++ component "VCBuild.exe".
To fix this, 1) install the .NET Framework 2.0 SDK, 2) install Microsoft Visua
l Studio 2005 or 3) add the location of the component to the system path if it
is installed elsewhere. [C:\Users\...\AppData\Roaming\npm\node_modules\particl
e-cli\node_modules\serialport\build\binding.sln]
I’ll try re-installing node.js
I am runnning the x64 version of 0.12.7 of node. It was working before.
ScruffR
November 11, 2015, 1:29pm
11
You have not by any chance upgraded to Windows 10?
If so, you might need to (re)install the .NET Framework 3.5 (which contains 2.0 too).
This easiest done via Contral Panel - Add/Remove Programms -> Add/Remove Features.
No. I’m on windows 7, and planning to stay there with this machine.
ScruffR
November 11, 2015, 1:39pm
13
Then I’m at the end of my wits and have to hand you over to cleverer guys like @kennethlimcp or @suda
Thanks for your help @ScruffR . I will try reinstalling .net, maybe there was an update that changed it.
Moors7
November 11, 2015, 2:58pm
15
You could give this a try, which has worked for me in the past:
So, in an effort to make local building easier for people, I put together a basic installer for the Toolchain for Windows. It should download and install GCC Arm, GNU make, and the necessary components of the MinGW toolkit, and add them appropriately to the path. I generally followed @kennethlimcp ’s guide here . I tested it on Win 7, so if something doesn’t work, let me know and I’ll try to fix it! This should decrease the number of steps necessary to get up and running with building locally…
You can select what you want to install, including the CLI
What does particle config identify say?
Right now I can’t get CLI to install. I’m running the toolchain installer, hopefully that will work but it will take a while with satellite internet connection.
Ran the toolchain, it installed everything with no errors. But the command line doesn’t recognize particle-cli and when I try to npm install particle-cli, it still fails with the same MSB3428 error.
ScruffR
November 11, 2015, 10:26pm
19
Command line won’t understand particle-cli but should know particle
And the npm line should look like this npm install -g particle-cli (-g for global install)
Okay, so I was on the road for a couple days and haven’t been able to work on this. Before I left, I shut my computer down and it had some updates to install. One of those updates must have been important to this as when I came back, I ran npm install and it worked!
particle list and flash --usb is working too!
My guess is the toolchain fixed whatever pieces were broken.
Thanks everyone who helped
