Whenever I try to flash with Particle dev I get the error “Build didn’t produce Error: Comma…” I have a breathing cyan but cannot reflash since my last sketch. Plus my tinker app shows my device as offline. Any ideas?
UPDATE
After a factory reset and trying to reconnect with app I get an error that reads.
Oops!
“Setup process couldn’t disconnect from the Particle device Wi-fi network. This is an internal problem with the device, so please try running setup again after restarting your Particle device and putting it back into listening mode (blinking mode LED) if needed.” Obviously, I’ve done that with no results.
I get it back connected and then when I try to flash again same error with Particle dev and web IDE puts it in breathing magenta indefinitely. I can however tinker the D7 LED with my phone. Are IDE’s down?
