Can't flash working code - Error: Could not compile. Please review your code
Hi guys, I need your help.
I have 2 Particle devices, let’s say:
  1. “bedroom”- Core (Black)
  2. “living room” - Photon
Today I occasionally flashed the “living room” with the bedroom code (forgot to change the device)
After selecting “living room” device, I can’t flash it with the living room code anymore. I made no changes to the code, but today in Web IDE I’m getting:
Error: Could not compile. Please review your code.
I tried to flash standard BlinkLED example - it worked. However my code still Could not be compiled.
I’m a bit lost. Any advice would be helpful
Ok, this one is solved. Got a new issue
Particle Core doesn't connect to WiFi (blinking green)
I've followed both options from here:
no luck. - blinking forever
For the Core you can still perform a factory reset
Then do the stuff outlined in the post you linked above and see if it works again (should run Tinker again).
After a messy combination of various actions I got everything back on track :slight_smile:
