I recently updated to the latest version of the CLI with the ‘npm -g update particle’ command.
Since then, the output from simple compiles of code with syntax errors, ALSO giving the ‘Usage’ message, even though the command line usage is correct. For example compiling this simple program:
void loop() {}
void setup() {}
this is a syntax error;
Results in this output:
$ particle compile photon .
Compiling code for photon
Including:
foo.ino
Compile failed. Exiting.
Processing foo.ino
make -C ../modules/photon/user-part all
make[1]: Entering directory '/firmware/modules/photon/user-part'
make -C ../../../user
make[2]: Entering directory '/firmware/user'
Building cpp file: foo.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-6-m
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFORM_NAME=photon -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=6 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=0.7.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../communication/src -I../hal/inc -I../hal/shared -I../hal/src/photon -I../hal/src/stm32f2xx -I../hal/src/stm32 -I../hal/src/photon/api -I../hal/src/photon/include -I../hal/src/photon/wiced/security/BESL/host/WICED/ -I../hal/src/photon/wiced/security/BESL/include -I../hal/src/photon/wiced/security/BESL -I../hal/src/photon/wiced/security/BESL/crypto -I../hal/src/photon/wiced/WWD/include/ -I../hal/src/photon/wiced/platform/include/ -I../hal/src/photon/wiced/platform/GCC/ -I../hal/src/photon/wiced/security/BESL/supplicant/ -I../hal/src/photon/libraries/crypto -I../platform/shared/inc -I../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../dynalib/inc -I -I./libraries -I. -MD -MP -MF ../build/target/user/platform-6-mfoo.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DBOOTLOADER_SDK_3_3_0_PARTICLE -DPARTICLE_DCT_COMPATIBILITY -DSPARK_PLATFORM_NET=BCM9WCDUSI09 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=5 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,207 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\"" -fno-exceptions -fno-rtti -fcheck-new -std=gnu++11 -c -o ../build/target/user/platform-6-mfoo.o foo.cpp
foo.ino:5:1: error: expected unqualified-id before 'this'
../build/module.mk:267: recipe for target '../build/target/user/platform-6-mfoo.o' failed
make[2]: *** [../build/target/user/platform-6-mfoo.o] Error 1
make[2]: Leaving directory '/firmware/user'
../../../build/recurse.mk:11: recipe for target 'user' failed
make[1]: Leaving directory '/firmware/modules/photon/user-part'
make[1]: *** [user] Error 2
../build/recurse.mk:11: recipe for target 'modules/photon/user-part' failed
make: *** [modules/photon/user-part] Error 2
Compile a source file, or directory using the cloud compiler
Usage: particle compile [options] <deviceType> [files...]
Global Options:
-v, --verbose Increases how much logging to display [count]
-q, --quiet Decreases how much logging to display [count]
Options:
--target The firmware version to compile against. Defaults to latest version, or version on device for cellular.
--saveTo Filename for the compiled binary
Examples:
particle compile photon Compile the source code in the current directory in the cloud for a Photon
particle compile electron project --saveTo electron.bin Compile the source code in the project directory in the cloud for a Electron and save it to
electron.bin
Param deviceType can be: core, photon, p1, electron, etc
I understand all of the output about the deliberate error I placed in the code, but why then go on to report "Usage: " etc?. It never did that before.
Thank you
