Compile failed. Server Error
As of 18 hours ago I have not been able to compile using cli "particle compile photon". I get this message at the end of the compile:
Compile failed. Exiting.
Server error
Others have had this issue in the past:
and
Out of interest, when trying to compile from particle-dev, it says "Success", but does not create a binary file.
I have 73 source files in the src sub-dir plus less number of files in the lib sub-dir and so perhaps this is the issue...
Could you try compiling a known good app, something like Tinker, to rule out coding issues?
Good idea, back soon (that said, I did get it to compile once or twice successfully).
@Moors7, guess what?
Downloading firmware source (by mistake, was meant to be Tinker source) from https://github.com/particle-iot/firmware/archive/v0.7.0.zip timed out… trying again and still waiting. Pings to github are okay…
Hmmm…
I note that 18 hours ago issues started at home and now I am at work - so time and space were diverse.
Web sites are coming up okay.
Do you know what domain I should ping for the compiler service?
Now I can compile the original source:
downloading binary from: /v1/binaries/5ac723dab4d9440aeb8b67ed
saving to: photon_firmware_1523000251975.bin
Memory use:
text data bss dec hex filename
110028 2480 7884 120392 1d648 /workspace/target/workspace.elf
Compile succeeded.
Saved firmware to: C:\projs\R620_IOT\particle-iot\photon_firmware_1523000251975.bin
And tried again 30 seconds later and it failed.
Theory is now rounding on external network issues.....
I will close this ticket once it is understood as to where the network is clogging up (am in Melbourne, Australia).
Problem was still in play this evening:
Server error
I upgraded particle-cli from v1.27 to 1.29 AND deleted the non-required .particle.ignore that I had added (refer to CLI Compilation - Flattening, Ignoring, Etc - #8 by UMD).
Problem solved!
I should have removed .particle.ignore. first before upgrading, but didn't.
What I did do was put .particle.ignore. back to see if this was the cause, got this:
Server error
Compile a source file, or directory using the cloud compiler
Usage: particle compile [options] [files...]
Global Options:
Am 80% sure that the problem is the particle-cli version because .particle.ignore. was added after the problem had come up.
Case closed!
PS - NOTE that "Server error" comes up if you use wrong parameters in the command line, eg "particle compile photon -v"
Spoke too soon.... this morning back to the same error return:
Server error
Usage: particle compile [options] [files…]
Global Options:
ie the particle cli update does not fix the issue.
Am now going to chase the too many source files theory.... back soon.
After detailed investigation I can say with a high probability that the issue is related to:
  • the overall number of lines of code - whether or not they are just comments or in #ifdef blocks
  • when you compile - ie it is random in nature
This fits in with how this issue first arose for me:
working fine -> developing new (working!) code -> Server Error
It seems that I am on the limit of what the cloud compilation service can handle.
Conditional compiliation may be the answer - have raised this ticket:
Any other thoughts?
I will keep this ticket open because it needs to be sorted!
So now it is working as it should, with all my source files in place, \
Conclusion: clearly pointing to an upstream issue - either internet connectivity and/or (most likely) cloud compiler service.
Is there some clue in that it is now a weekend which one would assume has less compilation activity?
Am closing this ticket as it is “solved” in that we better know what is going on.
