Electron flashes magneta (breath on off)
Flash success! by CLI and by Web IDE
The electron start blinking cyan and latero on start flashing magneta (Breath on/off).
is it due to cell network privileges?
Breathing magenta indicates Safe Mode, most often caused by a mismatch in system/user firmware. Do make sure the system version is >= user version before attempting to flash.
Try updating the system version using the CLI.
Updating the system version or the device version (firmware)? I think that only can be updated the device firmware. Thanks
particle update
will update the system firmware (current default version 0.6.2)
particle flash ....
will (usually) update the application/user firmware
