I had an asset tracker kit working, when suddenly it will not go all the way to breathing magenta after upstart.
It comes to the point where it is blinking magenta, then it blinks fast red 3-4 times, a little green and then blinking magenta and it does that 20-25 times, eventually the red and green blink disappears and it is just blinking fast magenta.
I had another new Electron and swapped it out, programmed it with same firmware and it started up without problem breathing magenta. So no startup problems and that indicate the my first electron now have a HW problem. Any advise to verify HW fault? In the documentation there is a description of SOS pattern with 3 fast red blink then 3 long red blink and then 3 fast red blink again. But my red blink was all very fast…
Program did not work correctly on the new electron! Should it be possible to replace one electron with another if it run the same program/firmware. Or how do I check OS/bootloader versions…
Hope there is a way to recover my electron…
Any suggestion is appreciated.
