Hello, Im looking to create a board that plugs into the main (52 pin i think) connector on the e-series dev board, does anyone have a link to the opposite / male connector that mates with the dev board connector? Through hole or SMD will work.
This doesn’t really answer your question, but because the connector is an odd length and for strength I usually use through-hole male header pins.
Then you can use a two single-row breakaway header pins like the Sullins PRPC040SAAN-RC side-by-side and just cut them to length.
according to this pages BOM spreadsheet,
https://github.com/particle-iot/e-series-evaluation-board/blob/master/bom/e0-dev-bom.xlsx
it’s a kaweei cs25402-52g-s85-a 26x2 female header 0.1inch pitch
but google knows very little about it.
