Electron SPI Pinout
Hello,
I recently started using E-Series for our project. I know that SPI is one of the options available to use for bus signals but I am having a hard time locating the right pin for (SCK, CS, MOSI, and MISO). I will appreciate your help with info on this.
Are you looking for this?
https://docs.particle.io/datasheets/electron/e-series-datasheet/#pinout-diagram
https://docs.particle.io/reference/device-os/firmware/electron/#spi
Thanks for the info. I will check if this would work. I have attached the image of the E-Series we’re using below.
