Hello Everyone,
I am looking to make a custom PCB and putting the particle Electron and adding some resistors. I was wondering if anyone else has every accomplished this, and what their process was. Would people recommend adding female headers on, doing through holes and hand soldering, or if surface mounting is even possible? I am planning to produce about 100 units.
I saw that there is this data sheet. However, this is for the particle Proton. Are there any differences I should know about?
Also side question:
How difficult would it be to integrate my own temperature sensor design into this pcb vs adding a spot for a break out board sensor? (cost and time wise)
Thank you,
NicoleN
