electron will blink green ~20, then cyan ~1, then breathe white ~2sec, then repeat. this started at some point overnight on tues night. up to this change it had worked well for at least 2 weeks.
i can do dfu mode on electron and when i enter particle update i get notice the firmware updated and
it returns to the pattern in the clip. i can put it in listening mode and it will message identity info when
particle identify is entered.
my other electron, the 2g one, has continued to work with no issues.
electron will blink green ~20, then cyan ~1, then breathe white ~2sec, then repeat. this started at some point overnight on tues night. up to this change it had worked well for at least 1 week.
this is link to video video
i can enter dfu mode and do particle update
but it returns to sequence in video.
it will enter listening mode
and particle identify lists info
I have had several of my devices do this as well. Half the time it is fixed by pushing out the pins on the sim card. But be careful you don’t break the pins. I still have about 10 electrons that permanently do exactly what your electron is doing. Not permanently green, so it is doing something, but it can’t seem to hold a connection.
