Message from resetting server & device keys on electron
hello, when running the device doctor the device updated firmware ,flashed the device doctor app, cleared EEPROM storage however when resetting the server & device keys it failed with this message,
Resetting server and device keys
Put the device in DFU mode
Tap RESET/RST while holding MODE/SETUP until the device blinks yellow.
? Select Continue when ready Continue
Okay! New keys in place, your device will not restart.
New Key Created!
I couldn't find the file: device id_ec_new.der
Make sure your device is in DFU mode (blinking yellow), and that your computer is online.
Error - I couldn't find the file: device id_ec_new.der
The Doctor didn't complete sucesfully. undefined
Please visit our community forums for help with this error:
i tried searching the forum on keyword device id_ec_new.der
but nothing came up. a search with google on the net also on
keyword device id_ec_new.der also had no hits.
however you will notice that in the error message itself the word
successfully is spelled wrong.
the device when reset goes from breathing white to blinking green.
i do have a battery attached as well as plugged into usb. this electron
has been operating with no problems for a ~week. i get the same error
message if i run a standalone particle keys doctor
Hi @dkryder,
The CLI wants you to replace the text “device id” with the device id of your device. Put your device into listening mode (hold setup button until the led blinks blue), and run particle identify.
David
yes, i’m aware of that. i was using the term as a placeholder for the actual id in the error message.
does anyone know what directory the file 44002c000xxxxx37353037_ec_new.der would be?
otherwise file deviceID_ec_new.der running keys doctor throws the error that it can not find that file.
ok, well my device is still blinking green ~30 sec, then breathe cyan for 2 sec, then solid white for 1 sec, then repeat with green blinking.
during last 7 hours, no change. i decided to log out and log in again and this is what i get when trying to do device doctor
\WINDOWS\system32>particle device doctor
The Device Doctor will put your device back into a healthy state
It will:
  • Upgrade system firmware
  • Flash the default Tinker app
  • Reset the device and server keys
  • Clear the Wi-Fi settings
    You're not logged in. Please login using particle cloud login before using this command
    as you can see i'm instructed to login
C:\WINDOWS\system32>particle login
? Please enter your email address dkryder@gmail.com
? Please enter your password [hidden]
Successfully completed login!
as you can read, i'm now successfully logged in,
i again try device doctor
C:\WINDOWS\system32>particle device doctor
It will:
and i'm again instructed to login, which i successfully did less than 30 sec ago.
anyone have any suggestions?
other thing i have tried
device doctor from early this morning
It will:
The Doctor will operate on your Electron connected over USB
You'll be asked to put your device in DFU mode several times to reset different settings.
Updating system firmware
Your device is ready for a system update.
This process should take about 30 seconds. Here it goes!
! System firmware update successfully completed!
Your device should now restart automatically.
Flashing the Device Doctor app
This app allows changing more settings on your device
Flash success!
Clear all data in EEPROM storage
Cleared EEPROM data
New Key Created!
I couldn't find the file: 44002cxxxxxx353337353037_ec_new.der
Error - I couldn't find the file: 44002cxxxxxx353337353037_ec_new.der
C:\WINDOWS\system32>particle server doctor
particle: Unknown command: "server"
C:\WINDOWS\system32>particle keys server
Found DFU device 2b04:d00a
spawning dfu-util -d 2b04:d00a -a 1 -i 0 -s 3298 -D C:\Users\dkryd\AppData\Roaming\npm\node_modules\particle-cli\keys\ec.pub.der
dfu-util 0.8
ID 2b04:d00a
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DfuSe interface name: "DCT Flash "
Downloading to address = 0x00000ce2, size = 320
Download [=========================] 100% 320 bytes
Download done.
File downloaded successfully
Invalid DFU suffix signature
Cannot open DFU device 2b04:d00a
flash tinker
C:\WINDOWS\system32>particle flash --usb tinker
spawning dfu-util -d 2b04:d00a -a 0 -i 0 -s 0x08080000:leave -D C:\Users\dkryd\AppData\Roaming\npm\node_modules\particle-cli\binaries\electron_tinker.bin
dfu-util 0.8
ID 2b04:d00a
dfuIDLE, continuing
Downloading to address = 0x08080000, size = 5776
Download [=========================] 100% 5776 bytes
Download done.
Flash success!
device doctor
It will:
Flash success!
Cleared EEPROM data
New Key Created!
I couldn't find the file: 44002xxxx351353337353037_ec_new.der
Error - I couldn't find the file: 44002xxxx351353337353037_ec_new.der
and sorry about not having code box but it was not an option by clicking on gear.
