Out of about 80 Cores so far, I have four that are flashing green after initial WiFi Credential setup. (They cannot connect to wifi or the cloud).
I have tried flashing the CC33000 patch via dfu-util, but this did not help.
Any Idea what’s wrong here?
I could load my firmware.bin via dfu-util and it runs fine. But all the WIFI / Cloud functions do not work as it can’t connect.
Again, that’s 4 out of about 80 that show this problem. To me, that’s a pretty disappointing ratio… Bad quality control?
Oh, and out of the same 80, I have two with a bad RGB LED. Only one or two colors work. Looks like bad soldering to me. If you push down on it, it does make contact and the LEDs work.
Arne
