I will assume the same will apply to me as well since both of my cores are kickstarter versions as well. Just finally getting a chance to use them. If I ever get the CLI installed I will try the update. Now to get the cliโฆ
Yeah, unfortunately, Iโve been through that tutorial and many others. Every error I fix a new one pops up. My computer needs a reformat so I am going to to try again with fresh installs. Hopefully that will fix the issues I am having. Have to be away for work a couple days, hopefully this weekend things will pan out.
HI, Iโm experiencing the same problem, I simply cannot get the Coreโs out of the solid Magenta. Unfortunately Iโm not getting the spark-cli installed on Windows nor on my raspi.
What to do now ? How will I ever get these 2 jewels to work again ?
@kennethlimcp I just did the dfu-util reinstall of the firmware, I got both Coreโs back to work. Thanks for showing me the right way to get both Coreโs back.
KR,
Rudy
These commands no longer work. I could no longer flash new firmware (timeout), so I did a factory restore and now it shows the same behaviour as in the video.
