Cannot connect Photon 1 board on either CLI or website
Hello all,
On setup.particle.io, I’m trying to connect my device to my computer via USB.
My photon 1 board is stuck in listening mode, by the way, in case it matters. Goes to blinking green when first plugged in, and then listening mode after I hold “setup.” And it stays there.
After I press “select device” it does open the menu and list my photon.
I select it, press “connect” and then nothing happens. It just stays on the same screen as in the screenshot with no change. The photon board doesn’t change its behavior either, it just stays in listening mode.
If I press “select device” again, it will display the photon and list it as paired, but nothing happens, even if I try again.
Does anyone know what’s going on? Any and all help is appreciated, thanks.
I would first try using Device Restore USB to reset the firmware first, then go through setup normally. If that does not work, it may require the use of the Particle CLI.
