Bricked core? Green flashing after power problem (solved)
My battery powered, solar loaded weatherstation has run out of power two days ago. Now I have the problem that I am not able to bring back the core to the cloud. It always blinking green, no mather what I do.
This things I have tried so far:
  • factory reset (many times), the core responses then to the app as well over USB to set WLAN credentials, but does not connect after then.
  • cleaning memory
  • programming timber over USB successfully
  • patching with cc3000-patch-programmer.bin successfully
Its a core with UL connector. Antenna is attached.
I believe that a brown out condition during power loss has killed some setting somewhere.
A new core with UL connector was up and running within minutes using the same environment.
Any ideas?
@digixx
The fact that the Core is able to talk to the phone app and get the WiFi credentials, suggests that the hardware is working fine. May I suggest using the Spark CLI to update the patch on the Core using the following commands:
spark flash --usb cc3000
spark flash --usb tinker
You could also try using a different antenna and a power supply.
Please let us know if this helps!
Best,
Mohit @ Spark
Hi Mohit,
Ok, I installed Spark CLI.
C:\>spark cloud list
Checking with the cloud...
Retrieving cores... (this might take a few seconds)
BEEBASE (48ff6e0....91287) is offline
test (48ff6e06......025241387) is offline
weatherstation (54ff67066....512367) is offline
BEEcore (54ff700666.....181367) is online
BEEBASE ist the broken core.
If i run these commands:
Which core is touched?
BEEcore is the new one I programmed today as replacement.
The update process will happen over USB as mentioned in the command, so the one connected to you computer will get updated!
Sorry, it was a bit too late that day.
So I tried as you described …
YES! its live again.
Thank you, thank you, thank you.
