Boron404X SIM/Account
@JynaeJones -Are you working through https://setup.particle.io/ or something else:
After a while, a prompt appears asking
What do you mean by after awhile... seconds or minutes? It should go pretty quick to detect the device and almost immediately prompt you for permission to connect. What web browser are you using?
A little more info on the new setup process is also discussed here:
If you are still having an issue might be worth having @Colleen help out.
