Hey @RyanL - I took your support ticket, but I figured it would be nice to try and resolve it here. Can you follow the instructions here: https://support.particle.io/hc/en-us/articles/360045547634 to set up via USB? For troubleshooting purposes, this can usually be a bit more streamlined and easy to debug.
Thank you for the link, that’s brought me closer. Now I’m getting an error when connecting to wifi:
particle usb start-listening
particle serial wifi
? **Should I scan for nearby Wi-Fi networks?** Yes
? **Select the Wi-Fi network with which you wish to connect your device:** HomeNetwork
? **Should I try to auto-detect the wireless security type?** Yes
> Detected WPA2(PSK/AES/AES) security
! Something went wrong: Serial timed out while initially listening to device, please ensure device is in listening mode with particle usb start-listening
When I run the flash command, the light goes magenta (red/blue) for quite a few seconds, but then I get an error. Here’s the terminal…
particle flash --serial ~/argon-ncp-firmware-0.0.5-ota.bin
! PROTIP: Hold the SETUP button on your device until it blinks blue!
? **Press** **ENTER** **when your device is blinking** **BLUE**
sending file: /Users/ryan/argon-ncp-firmware-0.0.5-ota.bin
Error writing firmware: Transfer cancelled
Hehe, when you said WiFi I got confused - hope it’s clear that the Boron can’t connect to WiFi. The article I’d sent over had BOTH Argon and Boron in it.
I never even saw the Boron instructions until you just mentioned it. Nearly every article I’ve come across uses “Argon” and “Boron” interchangeably. Even the Quick Start guide swaps the 2 at random.
I’m so lost… I’ve been looking forward to using this kit, but the documentation is kinda all over the place.
