Hello
today I made my mistake (I hope last of this year). I flash my code and after this Boron flashing red and blue.
I started with particle update putting the DFU-mode, but to no avail. Now after several attempts and research on the community site and having performed the procedure to put it in DFU it remains in this state. There is no way to put it in listening mode or any other mode. I also tried with particle flash --usb boron-system-part1@2.0.0.bin -v or with particle flash --usb boron-tinker@2.0.0.bin -v but to no avail.
Thanks Valentino
Do you mean magenta (combination of red and blue)?
When the device is stuck in DFU Mode it often indicates that either the device OS update has not finished successfully or you have no suitable application firmware on the device (e.g. corrupted by a previous flash attempt).
Instead of downloading the binaries and flashing them I'd first try the default way
particle flash --usb tinker -v
particle update -v
In these three lines the -v stands for "verbose" and in order to assess the situation it would be good to investigate what the respective verbose logs tells you and if you cannot make sense of them you can always post them here ![]()
There might be also an alternative explanation for your device being stuck in DFU Mode, but for that we'd need to know more about the context.
e.g. when you power up the device what is happening before the final DFU Mode state? Are there any other (transient) colours to be observed? How long does it take to end up in that state? ...
A video showing the entire process (previous run, reset, boot-up, intermediate states, final error state) and potentially also tries to enter Safe or Listening Mode may also be helpful.
Hi @ScruffR the first time blink was :blink blue for few seconds and then blink red few seconds and begin with blue and so on.
- I therefore performed a particle update that after about 1 hr did not go in place continued blinking (magenta -red and blue at the same time)
- At this point I put Boron in DFU Mode and tried the indicated sequence but to no avail.
No possibility to enter Listening Mode (mode button). - It reacts with the Mode tap Reset sequence but then returns with blinking yellow.
This is the result after particle flash --usb tinker -v:
VError: Error writing firmware: Invalid DFU suffix signature
Error during special command “ERASE_PAGE” get_status
If I power down and power up they go directly in yellow blinking.
Sorry how to attach the video?
Thanks Valentino
In that case it would be useful to record what exact red blinks are happening (e.g. SOS + x)
This doesn't appear to be a verbose output. With -v you should rather get something like this
dfu-util 0.8
ID 2b04:d013
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 5324
Download [=========================] 100% 5324 bytes
Download done.
File downloaded successfully
Although the ERASE_PAGE seems problematic.
You can try to flash the bootloader binary via
particle flash --usb boron-bootloader@2.0.1.bin -v
To post a video you'd need to upload it to some other service (e.g. YouTube) and post a link to it.
BTW, it probably won't change a thing (as you probably don't have a factory image installed) but you can try the factory reset procedure
- press/hold MODE
- tap RESET
- hold till you get past yellow blinking into blinking white
- release MODE
If neither of the above helps you will need to file a support ticket.
Hi @ScruffR
this is the link in dropbox :https://www.dropbox.com/sh/jjp1s68xut4cde4/AACLe-YQLIwSOww4IU63dGQna?dl=0
So I do the command
press/hold MODE
- tap RESET
- release MODE
but nothing
And this the full log :C:\Users\valentino>particle flash --usb tinker -v
dfu-util 0.8
Opening DFU capable USB device…
ID 2b04:d00d
Claiming USB DFU Interface…
Setting Alternate Setting #0 …
dfuIDLE, continuing
Downloading to address = 0x000d4000, size = 11412
Download [ ] 0% 0 bytesInvalid DFU suffix signature
at C:\Users\valentino\AppData\Local\particle\node_modules\particle-cli\dist\cmd\flash.js:208:13
at processTicksAndRejections (internal/process/task_queues.js:97:5)
at async CLI.runCommand (C:\Users\valentino\AppData\Local\particle\node_modules\particle-cli\dist\app\cli.js:160:7)
at async CLI.run (C:\Users\valentino\AppData\Local\particle\node_modules\particle-cli\dist\app\cli.js:190:14)
caused by: Error: Invalid DFU suffix signature
at ensureError (C:\Users\valentino\AppData\Local\particle\node_modules\particle-cli\dist\lib\utilities.js:427:14)
at C:\Users\valentino\AppData\Local\particle\node_modules\particle-cli\dist\cmd\flash.js:208:24
Buon Anno
Best Regards Valentino
Hell @ScruffR
do you think I need to open a support ticket or are there any possibilities for recovery?
Best Regards
Valentino
I’d still open a support ticket, but maybe @rickkas7 has something else to suggest (in parallel).
Open a support ticket for sure. Error during special command “ERASE_PAGE” usually means the device cannot be erased, which is a hardware failure of the nRF52 internal flash memory, which would also match the symptoms.
Good morning
I opened a support ticket. Thanks for your help, sometimes I tell myself you would have been able to complete all my projects?
I wish everyone a peaceful New Year.
Valentino
