So we got it provisioned but could not get it programmed correctly. Then it started the infinite loop of purp, yel, blue listen, then SOS 8. So I did the evil deed of Unclaiming the device. Now it just seems bricked. I have downloaded CLI for my Win 7 but have no idea what to do. Any thoughts?
You can try this
- make sure you got the antenna and the charged LiPo connected
- put the device in DFU Mode
- run CLI
particle update tinker -v
- put the device in Listening Mode
- run CLI
particle usb setup-done
- put device in DFU Mode
- run CLI
particle flash --usb tinker -v
- check whether device can now connect correctly
- it not, put device in Listening Mode and run
particle serial inspect
and post the result here
BTW, SOS+8 (Out of Heap Memory) is an odd error for a fresh device. Are you sure you never flashed your own code to it?
I attempted to put it in DFU mode and it keeps going past DFU. No way to stop it. I held RESET and MODE and released RESET when flashing yellow. It goes to White quick flashing and then blue flashing (listening). So non-starter.
It’s got a bad mode button. Replicated same function on another working Boron by holding the mode button down at power-up.
