I have two boron LTE devices. One boron I’m able to get connected and the other one I’m not. The device that isn’t connecting I’ve used previously and had deactivated the sim. I’ve reactivated the sim but I can’t get the boron LTE to reconnect. I’ve reflash via DFU the latest firmware and still it stays blinking green.
I’ve reached out to tech support but haven’t heard anything back. In the meantime while I wait is there anything else I should try?
When I look at my console I can see two sims, but only 1 sim shows a device tied to it.
So I’ve reload the bootloader, the system-part1 and tinker using a combination of jtag and particle command line and it still wouldn’t connect to the cloud. I’ve put the device on a ethernet featherwing and was able to get it to finish setup and I can see it on the console. Now if I take the device off the featherwing it will not connect via LTE. The other boron I have here connects without issue.
I’m guessing either this boron has a hardware issue or the fact that I deactivated the sim and reactivated it is causing it not to connect over cellular.
Has anyone else had this issue?
I’m still waiting to heard back from particle tech support, but seems slow.
Hey there – sometimes SIM reactivation can take as long as 24 hours due to the somewhat non-performant API interfaces provided to us by our carrier partners. When did you issue the activation request?
Did you receive an email to let you know that the SIM activation was complete? Is the SIM marked as active in the Console?
With your ICCID in hand, support will be able to let you know if the issue is on the SIM side or an issue on the device side.
Hi @will, yeah it’s been almost 24 hours here is about 3 hours. I did receive multiple emails saying it was reactivated. Previously when I tried to activate it the phone app would get stuck at do I want to setup mesh or not.
The sim is marked active in the console.
I’ve provided tre ICCID so hopefully they will be able to figure something out.
Followup – it looks like the SIM has been successfully reactivated. Would you share the results of particle serial inspect to confirm that all the system parts are configured correctly?
