Asset Tracker case
I am trying to find a way of using the waterproof case that comes with the Asset Tracker kit in a reasonable way, meaning, in real world conditions.
The case has no holes for the connection of both antennas and the USB charging. Any suggestions?
In the Facebook Ads that I see everyday, I see the case of the link below with at least the two holes for the antennas. Where can I find this one? Or any suggestion on how to get a case that would fit this purpose?
Use a drill, Luke :smile:
But really, this looks like a standard box like below with 2 holes drilled into it.
https://www.aliexpress.com/store/product/best-hot-sale-ip65-waterproof-electrical-box-watertight-enclosure-with-transparent-cover-80-110-70mm-High/532486_32357618806.html
It is the regular case, which is the same as the Adafruit 903, with two holes drilled in it.
