2nd idea on AssettTracker case, any ideas??
Does all of the pieces fit into this one? Is their a top to it or just the container?
Yes all the pieces fit, 2 6mm holes for external antenna’s I need to move the placement on one. And make the USB cord hole larger. Has a slot for the internal antenna if used. The battery is what keeps throwing me off. I also added a voltage regulator for a true automotive application. Top is designed just not printed yet
