I was wondering if the enclosure for the Asset Tracker kit is available directly from Particle IO or can it be purchase from a third-party vendor?
John
John
Not sure if this enclosure is the same one or not, but looks like it might be the size I need.
Actually, the Adafruit 903 is exactly the same case as the AssetTracker kit. If you click through to the data sheet it has information about the manufacturer if you’re looking for large quantities.
I appreciate the quick reply! Thanks a lot!
Guys,
I asked the same question for the V2 Enclosure in this post because I can’t find it. If one of you know and would like to share on the new post I just created, it will be very fine.
