Thank you!
+1 for WPA Enterprise support. I just bought 5 Argons with the intention of using them on our University wifi (Eduroam).
Can I suggest updating the support page (https://docs.particle.io/support/particle-devices-faq/wpa2-enterprise/) to note that Argon does not support WPA2 Enterprise connections?
Dave
Photon with device OS 1.4.x and later definitely works with eduroam. It has taken since 0.7.0 to get this working - about 18 months.
I am not sure Particle has WPA Enterprise support in the development backlog for the Argon before 1.6.0. It is a different development than lift n shift from the Photon device OS because the network stack is different - due to mesh and ethernet support!
David, that is an excellent suggestion and I will file a doc change request to that end. Thanks!
I also have a handful of Argons who really want to live on eduroam. Adding this support would be awesome.
m
Has there been any update?
@ParticleD, is there any update on this? It seems like it has been in the pipeline for 18-24 months. I have a small handful of devices sitting in a university basement basically doing nothing until I can det them connected.
WPA2 Enterprise for Argon is not currently on the 6-month roadmap. It hasnāt been eliminated as a possibility, but is not a priority at this time.
Last check, is enterprise going to be supported at any point?
There is currently no plan to implement WPA2 Enterprise on the Argon. Itās not completely ruled out, but also is not very likely, either.
any updates on this? not being able to connect the argon to established wifi networks is very limiting
There is still no plan to implement WPA2 Enterprise on the Argon. Itās unlikely to be implemented at this time.
