I see there are 2 U.FL connectors opposing each other on the Boron BRN404X. We typically use only one but I would like to use two patch antennas on either side of our product. Is this second U.FL actually for a second antenna?
Matt
Matt
Hey, Thanks for the response. This diagram is helpful. I'm actually referring to the U.FL that's next to the chip antenna. The diagram shows it as #3 and that it's for an external mesh antenna. It doesn't say really what sort of signal that is. It has BT silkscreened near it which makes me think bluetooth, but I don't want to assume.
Yes, 3 is the U.FL connector for Bluetooth. The diagram was created before the Boron had Bluetooth support, and I never noticed the label refers to mesh (which is no longer supported) instead of BLE (is supported).
There is a chip antenna for BLE on the Boron module and that's the default. You need to enable the external antenna connector in software for it to be used (BLE.selectAntenna).
Ok, got it. Thanks!
