BRN404x with new Antenna
Got a couple samples of the new Particle Antenna - PARANTC41EA - and am excited to take it for a spin in some of the parks where I am having cellular performance issues.
The new antenna is quite a bit thinner and longer than the one that has come with the Boron 402 and 404 and I understand it is optimized for the bands that are most important in North America.
I wanted to start a thread on this as it may be of interest to others who are working in areas with poor cellular coverage. My plan is to deploy this in some parks that have had connectivity issues in the past and see if, over time, there is an improvement.
So, if you are in a similar position, perhaps this thread will help.
Initial questions:
  • Wow this thing is long - can I bend it to fit in my enclosure. This one is answered in the antenna guide. and the answer is “yes” as long as it is less than 90 degrees.
  • If I have a BRN402 with the old non-EtherSIM - should I swap out the Boron with the shiny new BRN404X at the same time? Or, said another way, will the new antenna help the older Borons?
  • If I have a BRN404X with an EtherSIM - what then?
There are likely other questions and some of you may have already started testing. Please let me know your thoughts.
Chip
Do you have a “design of experiments” planned by chance? I’m trying to think of a tangible side by side, apples to apples way to determine the difference. Maybe a BRN404 with the standard FXUB63 antenna right alongside a BRN404X with this new antenna, vs a BRN404 with the new antenna and a BRN404X with the FXUB63? By testing side by side various configurations we should be able to determine what the affect is of the BRN404X vs the antenna. Capture device vitals every 1 hour for each in a low signal strength area and capture the Signal Strength and Signal quality values. I did something similar when trying to determine the best antenna location in my enclosure to try and put tangible numbers to it. Just a thought…
When trying different antenna’s in the past, I had similar results with Signal Strength but the quality score from the vitals page was vastly different between two like antennas. One was very consistent whereas the other was a lot of variability. This was almost 12 months ago though and forgot the details.
Looking forward to hearing/seeing more with your results! Thanks for starting the thread!
@jgskarda,
Ideally, I would do the side by side test as you suggest.
But, the devices that are giving me the most trouble are also fairly remote. So, as a next best thing, I plan to do a “longitudinal” study. My devices report cell strength (RSSI) daily and connect time (a great proxy for cellular performance) hourly. Since I have months / years of data with the current hardware, I was thinking I would compare performance over an extended time (weeks / a month) and compute an average (RSSI and connect time). I also collect events such as missed connection, missed webhook response, 3hours, 1 day , 1 week disconnected and resets (also tied to cellular performance) in a log. So, I could see if these events dropped off with the hardware change.
Practically speaking, this is likely my best way to see if swapping out the hardware makes a difference. Unfortunately, the current partial outage may well cloud these results as many of my devices are impacted.
Open to other ideas. Hopefully, as the new antennae come into general availability, there will be folks who will be in a better position to construct a proper test.
Chip
Honestly… it sounds like your test is most meaningful. Even if something translated to a few points higher in a quality or signal strength score, what ultimately matters is the things you are tracking. When I get an antenna or two myself, I may do some quick side by side but checks but generally speaking, I like your test setup much better.
@chipmc
The “new” antenna design would have been nice to know about 6 months ago as we sat spinning our wheels waiting for the new Boron. Now I have an antenna that is roughly 30mm longer than the old design. Not to mention I cannot fold it more than 90 degrees. Again, I have now wasted 6 months waiting for this and it will not fit in my design!
As if that is not bad enough, I just received 10 brand new 404X LTE M1. None of them will connect to cellular even though the old Boron is sitting right next to it breathing cyan.
What an absolute shame.
Was the question regarding whether the old antennas can be used with the 404X answered? I literally just opened my first 404X and also have a potential enclosure issue.
Tim
The old antenna (ANTCW2EA) works with the BRN404X (and B404X) which ships and was certified with the new antenna (PARANTC41EA). However, the BRN404X and B404X are not certified for use with the old antenna, and getting FCC intentional radiator certification is expensive. Also the new antenna has better performance on band B12, which is the primary band used in North America.
https://docs.particle.io/hardware/certification/antenna/#cellular-antenna-substitution
PARANTC41EA can be gently bent around the corner of an enclosure, which solves most issues with it being longer than ANTCW2EA.
FYI we conducted extensive antenna tests on many different brands, and the conclusion was that among good brands there is meaningless difference and the key was to put the antenna far from any metal (including the PCB). We saw a big jump in performance using external antennas, and another one using directional antennas.
@chipmc - Were you able to collect any tangible data on the
I think you collect better more tangible data than most of us do as it pertains to disconnects, connection times, etc. Have you had the chance to do any longer term comparison of original BRN404 antenna to a BRN404X with the new antenna?
I’ve been commissioning more and more devices in my basement with generally lacks cellular connectivity but always had just enough to connect, test run call some functions, etc. in the BRN404 days, it seemed I’d have to wait longer for a connection and occasionally the function calls wouldn’t go through. With the BRN404X I haven’t noticed the same issue and it seems to connect faster and be more responsive to particle function calls. I lack any tangible data though… Figured I’d check with you given your install base and the great data you collect.
@jgskarda ,
Unfortunately, on the deployments I have made so far, the next device / antenna has not made a significant difference. I will keep deploying the new devices but, so far, have been seen a big enough difference to say one way or the other.
Chip
