BLE/Mesh antenna needed for BRN404X?
Hi, the documentation here says:
The B Series SoM (system-on-a-module) requires the external BLE/Mesh antenna connected to the BT connector. The SoMs do not have built-in antennas.
Does this mean that the Boron BRN404X has its own antenna, unlike the SoM?
And for when we need the antenna for the SoM, where do I get one? I don't seem to be able to find one in the Particle store.
All Borons (including the BRN404X) have a built-in chip antenna, and a U.FL connector for an optional external BLE antenna.
If you want to use an external antenna, see the Antenna Guide. It’s the ANT-FLXV2.
Copy, thank you!
