Hi how are you??
I am not able to see my xenons conected to my argon gateway they say they are offline and I can not add them again using the app. Anyone else having this issue? Is this functionality already gone?
thanks
Hi how are you??
thanks
Xenons should be able to be added to mesh networks until 1.6.0 is released.
How long ago did you create the mesh?
Have you tried using the command line to add them? particle mesh add "e00..." "other_device" -vv.
Hi Guys!
Thanks for the help, I Manager to fix the issue by creating a new mesh network.
Again Thank you.
No worries. I suggest you add all the mesh devices near when you create the network. I’m convinced there’s a bug that prevents them from being added after some amount of months without some trickery.
