I have a few Photon 2s that I'm developing with, and it's a small annoyance to have to manually identify them each time I flash locally. If I have a single device plugged in, I think it would make sense to just program that device instead of specifying which device id it is.
Is there a different place I should submit feedback/feature requests for workbench?
That should be the way that it works.
When you Particle: Configure Project for Device select the platform and Device OS version. When asked for the device, hit Escape.
Then, if you only have one device of that platform connected when you do Particle: Flash application (local) it will flash whatever device is connected.
thank you
