Workbench list of all devices for login account
Hi... just wondering if Workbench have a similar feature as WebIDE whereby one can select device visually and then flash it.
No, the Particle: Configure Project for Device command has a text input box that accepts a name or Device ID.
However, if you Particle: Launch CLI you can use the particle list command, and it contains some useful filters:
particle list online    # show online devices only
particle list boron     # show boron devices only
particle list --help    # show other options
Thanks Rick
I guess I can use the Workbench for testing (debugging) then use the WebIDE for bulk flashing..
I'd strongly recommend using Product Firmware releases for Bulk Flashing :slight_smile:
