I am using I am using Particle Workbench on Windows 11 and I have it working, however I switch between devices (2 Argons and 1 Boron), is there some mechanism that allows project profiles to quickly switch between the devices instead of having to go through the project configuration every time? I’ve not found something like that, but it would be really nice to have.
You can click on the Platform indicator in the status bar at the bottom to switch between them.
click on argon and then select from this list
Thanks, that does save some clicks.
