Will not complete setup via app [SOLVED]
@maf,
I do suggest following the guide again but here’s what you can do for now:
  • press the SETUP button until the Photon blinks blue
  • Use the mobile app and go through the process of adding a new Photon.
I have a feeling you are using two different accounts since submitting a key via CLI would not have worked if the device is not claimed under the account in the first place.
