I cannot seem to make my new particle core connect to my computer. dfu-util never sees it, and neither does the particle cli.
While in dfu-mode (blinking yellow):
$ dfu-util -l
dfu-util 0.9
Found Runtime: [05ac:8290] ver=0146, devnum=3, cfg=1, intf=5, path="20-8", alt=0, name="UNKNOWN", serial="UNKNOWN"
And while blinking blue:
$ particle setup
_ __ _ _ _
| '_ \ __ _ _ __| |_(_) ___| | ___
| |_) |/ _` | '__| __| |/ __| |/ _ \
| __/| (_| | | | |_| | (__| | __/
|_| \__,_|_| \__|_|\___|_|\___|
https://particle.io
> Setup is easy! Let's get started...
> It appears as though you are already logged in as martin@abstractpuzzle.com
? Would you like to use this account? Yes
! PROTIP: Hold the MODE/SETUP button on your device until it blinks blue!
! PROTIP: Please make sure you are connected to the internet.
> No devices detected via USB.
? Would you like to scan for nearby Photons in Wi-Fi setup mode? Yes
! PROTIP: Wireless setup of Photons works like a wizard!
! PROTIP: We will automagically change the Wi-Fi network to which your computer is connected.
! PROTIP: You will lose your connection to the internet periodically.
> No nearby Photons detected. Try the `particle help` command for more information.
? Would you like to wait and monitor for Photons entering setup mode? No
> Ok, bye! Don't forget `particle help` if you're stuck! <3
This is a particle core, and I have worked with these before, but not this particular one. I’ve done a factory reset and tried both of these steps again. I do wonder if this has something to do with having to re-install node, and the particle cli. I had quite a bit of trouble getting both of those to work before I even got to this point.
