Once I start editing / fixing errors found during compile, the error screen is gone… How can I go back to see the last build errors while editing in the web IDE?
Try clicking it?
You can only open it again as long you haven’t saved your edits - once you save the source the error output will be gone and you need to build again.
As long you haven’t saved, you can click the icon in the bottom bar.
