Web IDE: File Limit?
Is there a limit on the number of files?
I have the main cpp and two libraries, so a total of 5, and the ‘+’ to add another file doesn’t show up anymore. It does for another app that only has 3 files.
I don’t think there is a limit at the moment, I’m guessing the button is just being hidden by the width of your browser. If you expand the window I’m guessing it’ll show up again. I’ll add a note for showing this control elsewhere for narrow screens.
David
Ah yes, you’re right. I did make it wider but still didn’t see the ‘+’, or the duplicate library file tabs. However I tried just now and once I made it super-wide to accommodate 3 copies of every library file (I’ve read the other thread so I know you guys are aware of that), I can see ‘+’ again.
