Use Boron without setup
I tried to use my Boron with 3rd party SIM but I cannot connect to the internet. It always enters listening mode. Is it possible to use the Boron without setting it up through bluetooth?
Yes, you can. You need to follow the instructions here to set the APN and set the setup done flag so you’ll exit listing mode.
https://docs.particle.io/support/particle-devices-faq/electron-3rdparty-sims/
Awesome it solved my issue!
