Unable to load libraries in workbench
Hi Team, I’m new to particle and I’m having some trouble migrating from the Web IDE to Workbench.
In Web IDE, I have successfully added libraries using the search function. However, when trying to load the same library name in Workbench using Particle:Find Library, I get the following “HTTP error 400 from https://api.particle.io/v1/libraries?filter=Grove_Air_Quality_Sensor.h - The access token was not found”
Any suggestions here?
make sure you’re signed-in - run the Particle: Login command :+1:
also, in case you haven’t seen it already we have a migration guide over here:
https://docs.particle.io/tutorials/developer-tools/workbench/#migration-guide
