[ISSUE] `HTTP error 400` when attempting to flash
My coworkers are not seeing this, so it’s something on my machine, but when I try to local flash using the new 1.6.1 buildscript, I get the following:
HTTP error 400 from https://api.particle.io/v1/devices/redacted - The access token was not found
I have tried cleaning, shutting down Workbench and restarting everything. Any hints on what might be wrong?
Wasn’t logged in to Particle via Workbench was apparently the problem.
That’d explain it, but I wish there were a better error if it’s going to suddenly require you to log in to use Workbench effectively.
I’m leaving this up in case anyone else runs into the same thing.
