I am so gonna "abuse"(read use) this forum. ![]()
I finally got a working electron to practice on. Installed VS and Particle bench. Now when I run a clean program
// setup() runs once, when the device is first turned on.
// Put initialization like pinMode and begin functions here.
// loop() runs over and over again, as quickly as it can execute.
// The core of your code will likely live here.
I get the following error: HTTP error 400 from https://api.particle.io/v1/devices/Test - The access token was not found
How do I fix this?
Second question is there a tutorial for absolute beginners I can work through. I wanna do MyPlant-Informer - Hackster.io as my first project but I need at least have to understand the basics of connecting and choosing the correct IO etc.
