A while ago my photon dropped off the network for some unknown reason and I didn’t have time to look at the problem then. Now I am trying to get it back online, and I can’t get it online.
It goes through all the steps, and then fails when it is verifying product ownership.
Are you using the same wifi location that you set the photon up on originaly? Has there been any wifi changes if it is? Are you using mac/Apple or PC/Android ?
Also if you log in to the console, is the photon listed on your account?
It is the same wifi location, same wifi access point, only difference is that my internet bandwidth got doubled, I even still got the same IP.
I tried to get it back on my network with my Android based phone, and now I tried with the Particle-CLI, here is what I got from that.
! OOPS: I was unable to scan for nearby Wi-Fi networks (-___-)
? We can still proceed in 'manual' mode. Would you like to continue? Yes
! PROTIP: Manual mode will prompt you to manage the Wi-Fi connection of your computer when it's necessary.
! PROTIP: To proceed, you will need to be able to manually change the Wi-Fi connectivity of your computer.
! PROTIP: Your Photon will appear in your computer's list of Wi-Fi networks with a name like, Photon-XXXX
! PROTIP: Where XXXX is a string of random letters and/or numbers unique to that specific Photon.
! PROTIP: You will need to know the password for your Wi-Fi network (if any) to proceed.
! PROTIP: You can press ctrl + C to quit setup at any time.
> Obtained magical secure claim code.
! PROTIP: There was a network error while connecting to the cloud...
! PROTIP: We need an active internet connection to successfully complete setup.
! PROTIP: Are you currently connected to the internet? Please double-check and try again.
I am 100% sure I got a working internet connection. I even tried to do it with an active SSH connection open, just sending constant garbage through that to detect any outtages. Only Particle-CLI can’t get connection.
In the concole I only got my old Core online and running, the Photon isn’t there.
Make sure the CLI is up to date, and then give particle serial wifi a shot while in listening mode. Enter everything manually if possible. Don’t know why, but it’s shown to be more reliable than the ‘auto setup’.
@Mikey, this would have been a question to answer, in order to possibly spare you this
If you said you were on Windows we might have guided you to the Windows installer that does all that for you
One possible reason for this may be a prolonged absence of the cloud. Keys get changed from time to time and if your device misses to many updates your device won't be trusted anymore.
