See this earlier post
But I'm sure efforts will be made to also support RCs.
In the command palette when you set your target device, if you are logged in, should it not show your devices? As opposed to having to know the device name or device ID and type it in?
FWIW, what I did (and worked) was:
Click gear icon bottom left, select Command Palete, enter “particle” and select Particle: Install local compiler from the drop-down list.
Hi, my project compile and working well. Here is project build step with my library.
It’s alpha so appreciate that it’s still a bit flaky at the moment, but hopefully this will provide a solid more co-herent platform for development and debugging.
So are we able to open existing projects or do we need to start from scratch by creating a project and then importing previous files, anything I open existing is not working.
Also, will it handle building of library projects or are we at the moment just at the firmware level ?
Currently there is no one-click way to migrate existing projects, but something that way is planned.
For now you’d need to create a new project and copy your sources into that.
Same goes for library creation. It’ll come.
Thanks @ScruffR
Suspected that would be the case. Looks good so far.
As a professional developer with Microsoft Technologies I am so used to Visual Studio and everything being nicely tied together and am really missing a nice co-herent development experience.
So keep at it guys, hopefully this will progress rapidly to a really good building process, which is a bit lacking at the moment. WebIDE is nice but lacks the GIT integration. Desktop with ATOM is good but lacks coherence.
So really hopefull with viscose as a way forwards. Looking forward to trying debugging.
Keep at it
Craig
Thanks for all the great feedback, everyone! Instead posted issues as replies in this thread, please create a new post and provide the information requested here.
I’m going to lock this thread from here on out and address issues posted here in a new thread.
