Help with particle workbench on code-server ( vscode )
Hi:
I just setup vscode server on kubernetes. However, it doesn’t have particle workbench extension since it’s not connected to the vscode marketplace. I had to install it manually using the vsix file (1.4.2)
The install went well but i don’t see any particle commands in the vscode command palette. I tried reinstalling it but no dice. Anyone using code-server and manually installed the workbench extension successfully? Could use some help to get it up and running. Thx.
Did you install all the required extensions?
particle.particle-vscode-pack
particle.particle-vscode-core
particle.particle-vscode-theme
particle.particle-vscode-snippets
ms-vscode.cpptools
marus25.cortex-debug
As an alternative solution, you can install neopo, which will give you most of the functionality of Particle Workbench through the terminal.
@nrobinson2000 I didn’t install the other extensions. I assumed the pack came bundled with all the other particle ones. That did it for me. Thanks!
