I am having trouble connecting my devices to our corporate WiFi. I have been able to connect to mutiple different WiFi networks without issue, but when I try our corporate WiFi it just seems to hang and give up when connecting.
I am using the web tool to connect (Configure Wi-Fi | Tools | Particle) and it reports connected and that the device will reset to connect and then just hangs and never connects.
Our network administrator says they never see any connection from the device.
I then ran the Doctor Tool (Device Doctor | Tools | Particle), flashed the device and then tried to connect to WiFi. I found the debug only reports the following:
0000000292 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000002606 [ncp.esp32.mux] INFO: Starting GSM07.10 muxer
0000002607 [ncp.esp32.mux] INFO: Openning mux channel 0
0000002608 [ncp.esp32.mux] INFO: GSM07.10 muxer thread started
0000002612 [ncp.esp32.mux] INFO: Openning mux channel 1
0000005304 [app] INFO: Auto-connect disabled
0000005943 [app] INFO: doing wifiScan
0000005947 [app] INFO: Doing Wi-fi scan
0000008478 [app] INFO: wiFiScan resultCount=23
0000027610 [app] INFO: setting credentials
0000027689 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000027697 [net.ifapi] INFO: Netif wl3 state UP
0000027698 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000030233 [ncp.esp32.mux] INFO: Openning mux channel 2
0000048554 [ncp.esp32.mux] INFO: Mux channel 2 already opened
0000066131 [ncp.esp32.mux] INFO: Mux channel 2 already opened
0000083126 [ncp.esp32.mux] INFO: Mux channel 2 already opened
Then last line "[ncp.esp32.mux] INFO: Mux channel 2 already opened" just keeps repeating.
When I try connecting to other WiFi it goes past this point and connects.
Any ideas what I can try next?
