Tinker Panics in 1.0.0?
Is anyone else having this problem, or conversely can someone else try this and see if they have the same problem?
I got a new Photon and when I try to do anything with Tinker from my iPhone it throws a kernel panic. I tried on one of the Photons I already had and got the same. I know Tinker worked on the old one under earlier firmware (0.8 candidates) but I haven’t used Tinker since the 1.0.0 release.
Running my own code on the unit it works as expected (so far). Using the manual functions from the WebIDE device console also throws a Panic so I don’t think it’s exclusive to my iPhone.
I didn’t have anything connected to I/O pins.
One unusual issue in my setup is that I’m in a rural area using satellite-based Internet service, so my round-trip ping time (as reported by diagnostics) runs 750 ms to 950 ms.
-Mike
On the Photon only, there is an incompatibility with the Tinker version installed on the device or flashed from the mobile apps when using some 0.8.0-rc versions and 1.0.0.
Upgrading Tinker by using the current version of the Particle CLI:
particle flash --usb tinker
will resolve this problem.
Or you can build your own copy of Tinker and flash it OTA. The source is available here.
