I just received my Tachyon board and accessories today and made a curious discovery regarding my particular setup.
I see quite a few people having issues with inconsistent or absent HDMI output when running the Ubuntu Desktop image so I thought I’d share my particular situation in case it helps others or if anyone has any ideas what the actual cause of my issue might be.
When I connected everything per the setup instructions and performed the setup everything went perfectly, but after powering the board off and back on again after the initial image install was completed and logging-in to the desktop I noticed the battery was not charging.
I checked the USB-C power supply connection to the multi-function USB-C hub (both power adapter and hub are the ones that were available as add-ons to the Tachyon kit on KS) and found that it wasn’t actually fully inserted. It took considerable force to actually fully insert the power connection to the hub, more than what I’d consider typical anyway, but not a ridiculous amount.
Once it clicked into place the battery status changed to ‘charging’ and all was well. That is until I rebooted or even cold-booted the board. I no longer could get HDMI output.
After thinking about it for a minute I decided to repeat my ‘accidental’ previous steps and fully powering down the Tachyon and slightly backing-out the USB-C power supply from the USB-C hub.
Bingo. My Tachyon will absolutely not output any HDMI signal whatsoever if the power connector is fully inserted into the USB-C hub at boot, but neither will it do so if it is completely disconnected! (note: I haven’t consistently seen the no HDMI when power is not connected to the hub, but seems more often than not to be the case.) So I have to boot it with the power supply connection partially inserted into the hub and once booted and I have the desktop I can then fully insert the power to the hub in order to charge the battery. The HDMI output is steady and unaffected as long as I fully insert the power connection into the hub after I get the initial HDMI signal output at boot.
Maybe others are having this same issue and don’t realize it. I would likely not have discovered the issue on my setup if that power connection on the hub hadn’t required extra effort to fully seat.
Now I’m left wondering is the issue I’m seeing with the hub? Or the Tachyon?
Regards,
Anthony
