I have plugged my usb c hub with external power into my tachyon’s usb1 connector and no video is showing on the monitor. I tried with multiple monitors and multiple usb c hubs and a usb c to hdmi adapter. I also bought the ugreen usb c hub from amazon and that is not working either. I tried flashing both desktop and headless variants but I still see no display getting connected when I try running modetest -M msm_drm over serial/ssh. I get these errors in journalctl:
Jul 08 21:56:04 tachyon-ecb0ee32 kernel: msm-dwc3 a600000.ssusb: DWC3 exited from low power mode
Jul 08 21:56:04 tachyon-ecb0ee32 kernel: [drm:dp_aux_configure_aux_switch][msm-dp-err][315 ]failed to configure fsa4480 i2c device (-5)
Jul 08 21:56:04 tachyon-ecb0ee32 kernel: [drm:dp_display_usbpd_configure_cb][msm-dp-err][315 ]aux_switch failed: -5, but continuing
Jul 08 21:56:04 tachyon-ecb0ee32 kernel: [drm:dp_power_clk_enable][msm-dp-info][315 ]core:on link:off strm0:off strm1:off
Jul 08 21:56:04 tachyon-ecb0ee32 kernel: [drm:dp_display_host_init][msm-dp-info][315 ][OK]
Jul 08 21:56:08 tachyon-ecb0ee32 kernel: [drm:dp_display_host_ready][msm-dp-info][236 ][OK]
Jul 08 21:56:10 tachyon-ecb0ee32 kernel: [drm:dp_panel_read_dpcd][msm-dp-err][236 ]error reading DP_TRAINING_AUX_RD_INTERVAL
Jul 08 21:56:10 tachyon-ecb0ee32 kernel: [drm:dp_panel_read_sink_caps][msm-dp-err][236 ]panel dpcd read failed/incorrect, set default params
Jul 08 21:56:10 tachyon-ecb0ee32 kernel: [drm:dp_panel_read_edid][msm-dp-err][236 ]EDID read failed
Jul 08 21:56:10 tachyon-ecb0ee32 kernel: [drm:dp_panel_read_sink_caps][msm-dp-err][236 ]panel edid read failed, set failsafe mode
Jul 08 21:56:12 tachyon-ecb0ee32 kernel: [drm:dp_link_parse_sink_count][msm-dp-err][236 ]failed to read sink count
Jul 08 21:56:14 tachyon-ecb0ee32 kernel: [drm:dp_link_parse_sink_status_field][msm-dp-err][236 ]DP link status read failed
Jul 08 21:56:16 tachyon-ecb0ee32 kernel: [drm:dp_link_process_request][msm-dp-info][236 ]event: DP_LINK_STATUS_UPDATED
Jul 08 21:56:16 tachyon-ecb0ee32 kernel: [drm:dp_power_clk_enable][msm-dp-info][236 ]core:on link:on strm0:off strm1:off
Jul 08 21:56:17 tachyon-ecb0ee32 kernel: [drm:dp_power_clk_enable][msm-dp-info][236 ]core:on link:off strm0:off strm1:off
Jul 08 21:56:17 tachyon-ecb0ee32 kernel: [drm:dp_display_attention_work][msm-dp-info][236 ]Hpd off, not handling any attention
Jul 08 21:56:17 tachyon-ecb0ee32 kernel: [drm:dp_display_host_unready][msm-dp-info][14090][OK]
I’m suspecting that all my usb c adapters are incompatible and the ugreen one I bought (Amazon.com: UGREEN Revodok 105 USB C Hub 5 in 1 Multiport Adapter 4K HDMI, 100W Power Delivery, 3 USB-A Data Ports, USB C Dongle for MacBook Pro/Air, iPad Pro, iMac, iPhone 15 Pro/Pro Max, XPS, Thinkpad : Electronics) isn’t the same one from the kickstarter. Can anyone confirm that this usb c hub is also incompatible? Is there anything else I can try? Thanks
