I have this configuration on a Muon:
SystemPowerConfiguration conf;
System.setPowerConfiguration(SystemPowerConfiguration()); // To restore the default configuration before making changes
conf.powerSourceMaxCurrent(900)
.powerSourceMinVoltage(5080)
.batteryChargeCurrent(1024)
.batteryChargeVoltage(4208)
.feature(SystemPowerFeature::PMIC_DETECTION);
int res = System.setPowerConfiguration(conf);
Log.info(" * * * * * power config API MODE setPowerConfiguration=%d", res);
I can see this applied since I observe:
0000003802 [app] INFO: * * * * * power config API MODE setPowerConfiguration=0
I am powering the Muon with 6v on DC Vin, exactly here:
Since I configured .powerSourceMinVoltage(5080) , I was expecting the charging to stop when I reduce the input voltage to 5v, or 4.5v, but I can see the yellow charge LED still on.
It only shuts off when the voltage goes lower than 4.2v.
Why would that be?
